My 2007 Legacy had leaks well past that in miles, but I didn't get a good look at where it was coming from due to not having equipment and place to do so (I live in a nice apartment complex that prohibits working on cars) but did notice both oil in the parking spot as well as oil usage that went up.
Note there are other places in the engine that can have oil leaks as well, such as valve cover gaskets.
With enough checking around the web, one of the things I've come to learn is the boxer engine is more sensitive to oil change frequency for head gaskets due to acidic oil, etc. because the gaskets are (at least for part of them) always in contact with crankcase oil, even when off. Due to financial hard times, there were some extended oil change cycles on my car, which I'm sure contributed long-term to needing new gaskets.
With such a low-mileage car, you're best off changing oil based on time or (if it's a bunch of short trips) much shorter mileage intervals for that reason. I had my head gasket replaced in February at about 118K miles, and you have an older car with about half the miles per year. One of the worst things you can do to a car is to not drive it, because it degrades from sitting, so you might as well have it wear from use than from dry rot!
