ok. Connection stuff.
I've gone through the connections before - the wiring diagrams and connection information don't match 100% in the factory service manuals. The 2015 manual seems to forget there is an amplifier available, and omits that section... 2016-2017 they got it right.... messed it up again in 2018-2019.
I've reconciled the connections for what I think is correct based on all that. Also - all of these are based on the US market vehicles. Think it's pretty much the same.
Going to the amplifier.... a mix of wires from several connectors.
These all would go to the 24 pin connector on the amplifier
11 wires total.
28 pin connector from radio:
Now, the 2018 introduced a second connection to the microphone. So instead of 3 wires, it's 6. Maybe dual mics or something. However - it shares the original 3 wires and connections that the 2015-2017 has. I think that will work ok.
Three wires out of that connector need to go to the amplifier, Pins 7, 8 and 16. 7&8 in the 2018 are a twisted pair (for RF protection).
that's it for that connector
10 pin connector from radio:
wires 1,2,5,6 need to go, these are shielded pairs. wire #3 is a shared power with one connection to the amplifier. need to run a wire for that. On your old radio, these would be simple speaker level outputs. On the 2018, it's the line out - so these should go to your amp, and the speaker connections would come back to the wiring for some of the front speakers.
6 pin connector from the radio:
wires 2,4,6 need to go to the amp. This is a shielded pair. Wire 4 is the shield. It is also shared with the shield in the two pair from the 10 pin connector. On your old radio, this would be the left hand rear speaker (maybe right side in your country - this stuff all assumes the US market).
2018 Connector | 2018 Function | Amp Input | Function | Note |
(i35) or (i85) No. 1 | FRONT-RH (+) | (i262) No. 5 | Right channel positive input | Shielded wire |
(i35) or (i85) No. 2 | FRONT-LH (+) | (i262) No. 3 | Left channel positive input | Shielded wire |
(i35) or (i85) No. 3 | +ACC | (i262) No. 12 | ACC power supply | uses same fuse/circuit as radio switched power |
(i35) or (i85) No. 5 | FRONT-RH (–) | (i262) No. 4 | Right channel negative input | Shielded wire |
(i35) or (i85) No. 6 | FRONT-LH (–) | (i262) No. 2 | Left channel negative input | Shielded wire |
(i36) or (i131) No. 2 | REAR-LH (+) / INT+*1 | (i262) No. 15 | INT+ | Shielded wire |
(i36) or (i131) No. 4 | N.C. / SLD2*1 | (i262) No. 6 | Shield | (i262) No. 18 connects to same shield/ground |
(i36) or (i131) No. 6 | REAR-LH (–) / INT (–)*1 | (i262) No. 14 | INT- | Shielded wire |
(i87) No. 7 | N.C. / TX1+ (for brand AMP communication)*1 | (i262) No. 8 | TX+ | Twisted Pair |
(i87) No. 8 | N.C. / TX1– (for brand AMP communication)*1 | (i262) No. 7 | TX- | Twisted Pair |
(i87) No. 16 | MUTE | (i262) No. 1 | MUTE | |
I included all this in a PDF - information in the general description section which shows a picture of the back of the radio and the amplifier - for these connector numbers. The chart is what you'd need to connect.
Outputs from the amplifier
all the speaker connections. There are more speakers from it than in your car, if you got the speakers too, they just hook straight to the amplifier. Spending money on expensive aftermarket is not a great bet, there is a lot of filtering and equalization going on, so a full range speaker where the amplifier expects something less is wasting the potential of the speaker. Plus the stock speakers fill up the mounting area nicely, less effort in trying to seal up aftermarket stuff for sound. Your call on that.
Speakers are:
Center Dash
Left/Right Dash Tweeters
Left/Right Front Door
Left/Right Rear Door
Subwoofer in rear.
There is an unused fuse box connection under the hood - that goes straight to the amplifier. 30amp fuse. This splits when it gets to the amplifier, there are two power inputs to that fuse for whatever reason.
Then you have to connect two ground wires. They run back through the harness to an engine ground. So just a good chassis ground should work.
I put together a PDF. It has wiring from the 2015, and the 2018. Has connection information in each section (for the radio, for the amplifier). The wiring diagram will have a connector number, and then there is a chart with the connection information.
Since there are a few errors, I put together a few spreadsheets and stuck that in the PDF.
- One is the connections of the 2015 vs 2018 radios to compare differences.
- one shows connections at the amplifier (inputs, speaker outputs)
- one shows what connections from the radio need to go to the amplifier and where.
- one is the working 2015 vs 2018 sheet, showing the errors, things that were corrected in the 2016 manual (2015 was a first run for the model), things missing in the 2018.
