2005 2.5I outback
Hello,
My headlight fuse keeps burning out after a few days. I bumped it up to a 20 amp and it still happens randomly, not immediately. Thoughts on trouble shooting?
Check the bulbs and sockets.
Check your wiring at the plugs to make sure they aren't frayed and shorting to ground.
Blown fuses indicate the Battery positive current is shorting to ground somewhere in the circuit the fuse feeds or the circuit is being overloaded beyond the rating of the fuse. With a higher amp fuse installed, you need to look for a short.
2017 Outback 3.6 Touring, which replaced '05 Outback XT
All good suggestions. I would also replace all of the bulbs on that circuit. They can develop internal damage that can short or use extra current.
I also recommend going back to the original fuse size. A short can cause wiring to catch fire. The fuse is sized according to the wire type in order to try to prevent that from happening. A short is nothing to mess around with.
