"Car: 2006 Outback sport 2.5i"
Is that the Impreza-based Outback, or the larger Legacy-based Outback?
If it's the full-size Outback, then yes, the daylight running lights (DRL) use the same bulb as the low beam headlights. When the DRLs are on, the low beam bulb is not as bright as it is when the headlight switch is used to turn on the headlights.
