1 - 2 of 2 Posts
Hi there. I'm having a weird issue with locking the doors on my 2005 Subaru Outback imported from Japan. The key fob wont lock or unlock the doors anymore, I tried a different FOB and multiple batteries with no avail. Also the central lock on the drivers door wont lock the doors either all it does in make two quite beeps when the switch is activated. Any help on this issue would be appreciated. Thanks
The fact that you're getting any response to the fob, and that the central switch on the driver's door doesn't work, suggests that the problem is not with the fob. Do the other door switches work?
1 - 2 of 2 Posts
