I found this when i was looking a recently replaced axle due to the car vibrating a lot more after the axle replacement. I'm not sure what the name of the part is so i can't really google the problem.
I'm guessing it has something to do with the suspension since it is near the wheel and all. The fluid leaking out of it is very viscous, kinda felt like rubber cement.
The problem is on the drivers side, the passenger side one looked pretty dry.
I'm hoping it is not something to worry about or an easy fix. If it isn't then i really need to find different mechanics because it has had two inspections within two weeks, with no flags raised. Plus, the guy who replaced the axle would have been working right near this thing, and I noticed the leak on the drive home from the axle replacement, so i'm assuming it had already happened, or was caused by something at the dealer.
