Hello all, and thank you in advance!
A/C recently stopped working in my 2004 Subaru Outback Limited (CA-spec emissions, if that matters) and I got my hands on a set of gauges. The following two states are what I have observed so far:
Car off, resting pressure:
High: 100psi
Low: 85psi
Car on, A/C on (cooling fan engages, as does the compressor clutch):
High: 100psi (essentially no change)
Low: 0psi
I haven't been able to find a similar scenario in my searches, and am not familiar enough with the system to start pulling parts... has anyone seen a similar scenario?
What additional info would be helpful in this diagnoses?
High: 100psi
Low: 85psi
Low: 0psi
