1 - 11 of 11 Posts
Got the Subaru back from transmission repairs yesterday. Today I get flashing red and blue temperature indicator with solid check engine and flashing cruise and brake lights. Eff me.
I'm going to get it towed to my mechanic, but I must say, I'm tired of this.
take it back to the trans shop and make sure they reconnected everything
alternating blue/red indicates electrical fault
Thank you. Good to know it's not likely something new.
Cheers.
So I pulled the code this morning...
P0117 - Engine Coolant Temp Circuit Low Input
Looks like it goes back in. Ugh.
I forgot to mention that last night (while I was taking the car off the tow truck) when I started it up, none of the warning lights were illuminated. Like it never happened. And they were still off when I went out to pull the code from the OBD reader this morning.
2012 Outback 2.5 Limited
P0117 is still just indicative of what @YeuEmMaiMai hinted - loose electrical connections. Check the connectors for the engine coolant temperature sensor. The reason why they might not initially have been off could be that the sensor initially had good connection but if it wasn't attached properly it might now have worked itself loose.
Thanks OBDad. I just dropped it off at my mechanic and he said (pretty much) the exact same thing. He's going to have a look and expects to have it back to me soon.
You guys are good.
Cheers.
Discussion Starter #9
I just put a new battery in. I cleaned the connectors and the ground. It should be ok. But I wonder if the guys that changed the valve body might have simply missed something simple. I hope that's it.
Cheers.
Discussion Starter #10
Just to close this off (hopefully) I have my beloved Outback home again and everything seems to be fine.
The shop replaced the 'coolant temperature sensor' and I am told that I'm good to go. Easy peasy.
Thanks for the ideas/input/help. Good to know you are all here in a pinch.
Cheers.
1 - 11 of 11 Posts
