1 - 7 of 7 Posts
I'm having issues with hard start after a refueling, hesitation at takeoff, and slight cutout at parked idle/rough idle in gear (more pronounced while running a/c). Replaced Evap purge solenoid by charcoal canister, solenoid behind RH side of intake, PCV valve, fuel filter, plugs, and wires. I'm at a loss. '01 Limited, 2.5 non-turbo.
03 H6 OBW & 06 WRX Sportwagon
scanned ECU for pending codes?
any whooshing-type noise when removing gas cap?
do you stop fueling when the pump handle clicks off or continue to 'top off'? Does another driver 'top off' the tank?
No whooshing sound, never top off, get a P1443, once in a while. Thought I had that fixed replacing the purge solenoid, but it came back on last night. My issue seems to have morphed somewhat to more of a hard start every time, and my wife says she had no issue when she fueled up the other day.
Wondering if it could be a fuel supply issue. Apparently, Subaru doesn't supply fuel pressure info through the OBDII port? My scanner shows n/a for that line, anyway. As my P1443 is so intermittent, could one assume that it may just be a gas cap, and the hard start is a separate issue? Fuel pump getting weak? Seems like that should be a little more consistent, as well. I'm frustrated, and fear I've lost my objectivity in analyzing this one!
I have had this issue since I bought the car. Could it be the previous owner having topped it off?
I've seen comments on other posts where folks have weighed the charcoal canister. Should I do that, and if so, what is a "healthy weight?"
1 - 7 of 7 Posts
