Switched out Lows & Fog lights to HID, LEDs on front position lights
I gotta say I just hate changing the Lows, it's such a pain in the keister. So after this last set blew after less then a year, I went with HID Xenon kits. Since I was changing the Lows I figured I might as well change out the fog lights as well since I've never changed them out and I run them all the time. One of my coworkers who is heavily into the tuning scene and has one sick Acura all moded out with twin turbos, intercooler and the works. He laughed when I showed him the Phillips kit I was considering at $200 a set. He pointed me toward DDM tuning.
DDM Tuning 35W and 55W HID Kits They mostly deal with BMW's but lights are lights. He showed me his conversion that he has been running for over two years with no problems. It looked really good, very bright and at less then $40 a kit for the 55 watt kit ($30 for the 35 watt kit), I pulled the trigger on 2 kits, 1 Low beams H7 & 1 H11 foglight kit, plus LED replacements for the front position lights above the High beams. I also got the mounting plates for the ballasts but they were not used as I couldn't find a decent spot to drill into where I could reach around for the nut of the mounting bolt. In the end I went with industrial strength Velcro as well as zip ties for safety.
I removed both front wheels, wheel wells, battery, and the entire airbox assembly on the passenger side so that I could find the best spot for the ballasts. Like others I went with under the rubber flap at the top for the low beams. For the fog lights I placed the ballasts on the lower body frame behind the wheel well next to the electrical wires for the fog lights. I used a plastic protective overlay for the wires like the OEM wires.
The Bulbs I choose were the standard 6000k like Phillips uses on the Euro Lux cars. They do have a slight bluish tint. It is more noticeable to the on looker then me as the driver. On the road it looks very white, but it is to be expected as the shear power (>5,000 lumens a light) of the 55 watt kit washes out a lot of tint. On the 35 watt kit I would expect that the blue would be more noticeable. The only difference I notice is coming off the white speed limit signs, they have a slight bluish tint now. They do offer a 5000k bulb which should be whiter and a 4000k that has a more standard halogen yellowish tint. Honestly I look at that Halogen yellow as being dull, old, and almost nostalgic.
I live at 7,000ft in deer & elk country here in Northern Arizona (not a lot of big predators up here besides man so some of these elks get to be the size of horses!). I run the fog lights all the time at night to better spot them on the side when they aren't looking my way. With the new set up I'm blazing up the road at over 20,000 lumen with both lows and fogs. The difference is incredible. With the fog lights I can see deep into the forest on the sides as well as ahead of the vehicle.
I haven't been flashed my other motorists or stopped by law enforcement. I think people are just used to seeing Lux and tuner cars with HID now. The only problem is the highlights. They're pretty much useless now as they are completely overpowered by the lowlights and I loose the fog lights with the high beams on. So the net effect is I loose a lot of peripheral light and all I get in return is a yellowish tint to the tops of the trees. They only serve as DRLs so I'll probably go with direct LED replacements like the front position lights if only because I now think the yellowish halogen looks nasty and out of place next to the LEDs and HIDs in my setup. The brightest H9 LED DDM sells is only 400 lumen, pretty weak for highlights considering my lows are putting out over 5000 each but should be more then enough for DRLs. When I can figure out how to post pics I will
