I press my horn and it honks occassionally. Usually after just starting the car and driving shortly down the road; after that, nothing. I tried checking the fuses, and used a good relay fuse in for the horn relay and that didn't work either. What can I do? Thanks.
Either the relay or the horn switch itself is probably the issue. Contacts can sometimes be intermittent.
SwordBearer,
And sometimes the wiring connector at the horn is corroded.
