1 - 10 of 10 Posts
Banned
Need a gas line removal tool. A couple of bucks at your local auto parts store. Slides over the line in front of the green ring. Push the green ring into the fitting and the lines pull apart.
ugg, head gasket job on a ez30D :frown2: hope it is not your first with one of these
. vs. just buying a nice cheap 212hp JDM and dropping it in.
what was that he said about 90*? - are the locking tabs in a specific orientation?
are there any o-rings that need to be replaced in those things? any lube required when put back together? do they just push together?
Master Caster
🖤💔💙 3 Beautiful OBXTs
No the tabs can be orientated any way, usually they have a memory from the hose. But the plastic clip will rotate inside the coupler to ant orientation.
There is an o-ring inside the coupler. O have never used any grease, or replaced any of them. The o-ring seats against a should and the whole thing is compressed by the clip and coupler. It's a b*tch of a design that works really well.
Banned
They are like shark bite plumbing fittings. There is an o-ring as part of the assembly but nothing that should need to be lubed. Just clean everything up before snapping back together.
Reactions: 1 Lucky Texan
1 - 10 of 10 Posts
