Hello!
MT 1999 OUTBACK swap in AT OUTBACK 2002. I can't get work a speedometer.
I set ECU in MT mode, conected by ground (B135 pin 25), and speed sensor is conected by ground and ignition, and third pin is conected by ECU B135 pin 24 (just like in cheme). But when I turn the sensor, speedometer is not showing anything. Conectors for transmission and TCM disconected.
It's still stay inside original AT. At first I need to get work speedometer, then I will make a swap, because speed sensor is the only think what not works when I make testings for electrical part.
In this corona time anyway isn't to do at home, so this is my free time project.
Thanks for any advice!
