Subaru by design has had soft pedal feel - its not your dads Domestic over boosted car.
A soft pedal does not mean poor brake performance by the way.
i have never seen a failed brake line on a Subaru, I think they're brake hoses are quite robust...or i've just gotten lucky.rubber lines can get soft and balloon - try new hoses at the wheels
interesting, why do folks dislike stainless? probably provides more feedback?some folks hate, others like stainless braided lines - your choice)
seen hose failure on other makes/models, so it's possible and current. haven't seen it yet on a Subaru....maybe luck or maybe metal rusts faster than rubber degrades so we never see it here.modern hoses may have better materials than in 'the old days' so - your experience is probably more pertinent
interesting, have never really read up on them but i bought two sets about 5 years ago and have never installed them yet. LOL i should probably think about that sometime soon!as for the SS braided hoses,I have read .............but I admit I noticed no improvement after they were installed -
I think, on an older car, it would be possible to notice some improvement IF the idea that old hoses 'balloon' a little is true. That said, replacement with SS braided OR new rubber would feel like an improvement I'd guess.seen hose failure on other makes/models, so it's possible and current. haven't seen it yet on a Subaru....maybe luck or maybe metal rusts faster than rubber degrades so we never see it here.
Soooooo, the Legacy GT calipers use larger pads, and can be swapped in on the Outback with no modifications? Sounds like the way to go, along with new rubber hoses and a master cylinder brace, if I can find one for the Gen2 Outback.
Every 2 yr/30k Fluid flush. Get the water out, pressure and boiling points return to normal; pedal pressure increases. Use semi-metallic pads. Greater friction force.probably have 10+ year old brake fluid in them, they rarely get flushed.
a thorough brake job should have it performing well and biting nicely.
flush the fluid
clean and grease the slides
turn the rotors or buy new
put some decent pads on it
