1 - 20 of 21 Posts
2010 2.5i LTD
I disconnected the battery on my 2010 OB at the weekend, to install a Media Hub. Now the driver's window no longer has auto-down/up. I know there's a magic trick to reset this, but I can't find it anywhere. Does anyone know the secret?
2014 Forester 2.5i Touring with EyeSight; Venetian Red
Pretty sure it's in the manual somewhere, I remember reading it. Double-check the maintenance section around the battery change instructions. IIRC, It involves closing the door, manually putting the window down all the way and holding down for another second, then putting up all the way and holding up for an extra second. Or something like that.
Elliot
Not sure about the Subaru but......In other cars I've had with express up windows, you open the window, close the window all the way with the switch in the 1st detent (not auto position) and hold the switch there for 10 seconds. This usually resets the load limiter.
Do the same with the moonroof.
2010 Outback Azurite Blue 3.6R Limited and 2001 Outback wagon 2.5
Initialization of power window
If the vehicle’s battery is disconnected due
to situations such as battery or fuse
replacement, the following functions are
deactivated.
. One-touch auto up/down function
. Anti-entrapment function
Initialize the power window in the following
procedure to reactivate such functions.
1. Close the driver’s door.
2. Turn the ignition switch to the “ON”
position.
3. Open the driver’s side window halfway
by pushing down the power window
switch.
4. Pull up the power window switch and
close the window completely. Continue
pulling up the switch for approximately 1
second after the window is closed completely.
2011 2.5 CVT Premium
Had this same problem. Dealership disconnected my battery because my headlamp went out on my 2010 Outback. That action reset all my radio presets and turned my auto window off.
The halfway down and back up then one second thing fixed it.
I would think that a dealership would be smart/diligent enough to reset everything needing resetting (other than radio presets) when they have to disconnect the battery!
At least I'd expect them to take care of that.
I don't expect too much from them... they took 2.5 hours to put in the new headlight, after telling me they've never done one before on the 2010 outback. They even considered taking off the actual headlight covering, but thankfully they didn't.
It's the only Subaru dealership near me and its one of those that are together with kia,suzuki,etc. It's clear to me that they don't have any knowledge of the newer models (you would think two years would be enough to gain that knowledge right?).
At least they were nice.
Hi,
We just got our OB this week. Do all the models have the auto up feature or is it model specific? I asked the dealer but they weren't sure. Ours doesn't do it but was hoping maybe it could if all I had to do is disconnect the battery and reprogram it.
2013 outback 2.5i premium
Thank you Ardvark11. Easy fix! The only bothersome thing is that the battery had not been disconnected and everything else with memory is fine.
Hi,
Auto down is standard on all trim levels. Auto up is standard on 2.5 Premium and up...
'00 Outback H6, '08 BMW 335i
Aardvark fix worked on my BHE Outback :)
2014 Outback 2.5i
For some reason I can't get the auto up feature to work with my OB... The auto down works just fine, but it won't go up automatically.
I've gone through the initialization process numerous times to no avail... See video: https://www.youtube.com/watch?v=OMTI1UIit5o
Anyone able to chime in on what I'm doing wrong?
EDIT: Just read a little closer...and saw a couple posts up that auto up isn't standard on the base models. There's my answer, I guess... Seems like a very silly thing to not include in the base models.
2015 Outback 2.5i Limited
Good info! This works for the 2015 Outback as well. I was freaking out that the windows weren't working properly after disconnecting the battery. I was looking for a blown fuse. FYI, I had to do this on both driver and passenger sides.
R.I.P. 2010 Outback Limited 2.5, 338,000 miles. Ran perfectly until it was totaled by a 1,400 lb. COW
so I tried this half open window method and it didn't work. the window goes down fine, but goes up only 1 inch with each pull. any thoughts?
1 - 20 of 21 Posts
