I have already had both rear wheel bearings replaced which caused a great reduction in the noise but I still get a faint metallicish humming/rubbing from the rear somewhere. The only thing I can think of is something to do with the differential but geez I do not want to spend that and I am going to change the gear oil tomorrow. Any thoughts on some cheaper routes to look at first? I have poked around a bit in the forum and seen mentions of a certain bearing in the driveline that can cause something similar but I cannot find a recording of the noises to compare it to.
The noise happens consistently louder relative to vehicle speed around 25MPH+ and does not change under throttle load or braking. You cannot feel any vibrations except something faint getting transmitted into the floor and even then you have to be going at highway speeds to even start to notice. Also all tires are full balanced and aligned, tire pressures right, there is no unusual play in the driveline, and there is no noticeable effects when cornering as in no changes in noise no shimmying etc. Also would you advise driving it under these conditions? Please help I just got this car and I love it to death and having already sunk $400+ into it within a month of getting it I am really getting anxious.
Thanks!
Davis
Thanks!
Davis
