My 2016 OB has about 69,000 miles on it. At about 57,000 miles, it started to make a humming noise that has since gotten louder. I was assuming it was a bad wheel bearing, but while reading up on what may cause this noise, I read somewhere that if the tread tire ware from front tires to rear tires is as little as 2/32" it may damage the center differential bearing and could cause this same noise. Does anyone know if this true?
2012 OB , 2017 Impreza
Not just front-to-rear. With ANY AWD vehicle, all tires must be replaced ALL FOUR AT A TIME. Any mismatch in tire diameter may cause the AWD system to think there is tire-slippage and try to engage the AWD system. Obviously, engaging the AWD system when all 4 tires are on pavement can cause undue stress on the AWD components and tear things apart.
Now... to address YOUR specific issue.
If I were you, I would NOT start by being concerned with a problem of the AWD system. Start with the EASY things like tires. Yes, some tires will get VERY noisy as they wear down. Also, a wheel-bearing can cause noise too.
2008 Outback 2.5
Does the noise depend on speed and/or make a difference while turning left or right?
Noise is constant. Rev's up as I speed up, but it is the same noise with no difference when turning either way. I wondered about the tire ware only because after getting a flat, I replaced the one tire (same make and model). The other tires had about 57,000 miles, but they were in pretty good shape tread wise. The noise started shortly after that.
UPDATE... I borrowed a laser heat sensor gun from work and over two trips back and forth to work I scanned the temps of all four wheel bearings. Three of the bearings ran within 2-3 degrees of one another the forth (front drivers side) was 10-12 degrees hotter each time. That was the one that sounded like where the noise was coming from to start with. I figured that might be the problem so I got a new front wheel bearing and replaced it, being careful not to hit the speed sensor. The good news is when taking it out for a test drive the whinning sound is gone. The bad news is ALL the dashboard idiot lights are on (check engine, ABS, AT Oil Temp., Cruise Control, X-Mode and traction control). I thought that maybe I hit the speed sensor, so I purchased a new one and replaced it, but it didn't help. All the lights are still on. Any ideas on what else to check? or do I need to clear them? How do I clear them?
