1 - 20 of 23 Posts
11 3.6R base
I have 200.00 in subie bucks that expire soon..
I need advice on what to buy...
I have a 3.6 with 111k on it...
I have plenty of oil filters...and a spare coil.
I have a new starter and master cylinder...
I was thinking what will go out next....water pump? or maybe axle shaft....or alternator...maybe fuel pump?
Your .02 would be great!
Garth
you actually have a trouble free car there, one of the ones people fight over. so no parts needed to buy for a failure.
_______
maybe some dealer accessories for your car. or some subaru clothing if they make such things.
_______
if you wanted to turn that into some bucks for you,...looking at the classified section here seems lots of WTB people are looking for wheel arch moldings for 2010-14 and 2015-present cars.
maybe contact them and fill one of their requests. (seems to be a color keyed item though).
11 3.6R base
Oil...not a bad idea...I was also thinking coolant...it says 137.5K or 11 years...
Buy a bunch of Subaru 5w30 and not worry about oil costs for a while.
does real subaru engine oil have lady samurai farts in it,...making it more valuable then what full synthetics are sold at wallymart?
2013 3.6R Limited
How long has it been since you did a drain-and-fill on your 5EAT? I do it every 30,000 miles as part of my routine oil & filter change / tire rotation. Takes maybe 20 minutes. Consider grabbing 10 to 12 quarts of Subaru HP ATF. That should get you through at least two drain-and-fills....
11 3.6R base
I have just done that too...I was thinking something that would stop working...
Consider stuff like transmission cooler lines, coolant, Subaru HP tranny fluid, Holts cooling system additive, cabin air filter, air filter, PCV valve, heater hoses etc. etc.
2017 2.5 Outback Limited no Eyesight
Floor Mats?
4 Wheel Alignment?
Other suggestions are good. How pitted is your windshield at 111,000 mi.
Brucey
'17 3.6
I mean if he has to buy something it seems like a solid choice for saving money even if the OEM stuff is pricey.
Motor, trans, and center mounts. It was some of the best $240 in parts we spent on the car. Feels like a new car again without the vibrations, clunks, and drive line slop and we did ours at 50k. I'm going to bet at 111k, the originals are done.
Regards
11 3.6R base
Discussion Starter #14
I do need rear struts...question is do I go stock or should I get an upgrade...
I can't comment on stock struts but I did just install KYB's and man o man what a difference!
Have you had any TPMS warning lights come on yet?
11 3.6R base
Discussion Starter #16
No TPMS yet...I have heard 7-10 years on the batteries...did you install the KYBs on all for corners? I dont want a stiff ride...but the rear on mine is starting to float on bumps :(
struts, now that is a good buy at the dealer as I don't think KYB has offered them direct yet. (KYB what subaru reboxes).
if you wanted a firmer ride then the 2010-12 offered,
you could buy subaru struts for a 2013-14 outback, and they bolt right up.
_____
the 2010-12 outbacks were originally panned by the press as being too soft and the car leaning too much in the turns, unlike what outback wagons had done from 2000-2009. the 2010-12 subaru ride was similar to the then new to the market Toyota Venza . (maybe subaru was trying to grab up some toyota camry, and chevy impala buyers with a couch like ride :hide: )
subaru revised the 2013-14 outback struts to firm them up slightly for less lean,...as the expensive soft rider Venza never did sell enough to compete with subaru outbacks huge sales #s.
Master Caster
Too bad I don't take SubaruBucks.
Bushing and bushings and inserts oh my.
1 - 20 of 23 Posts
