1 - 20 of 25 Posts
'13 Ouback 3.6 limited
What bulbs are you guys using?
I prefer to not do any conversions right now. Suggestions?
2005 3.0 R n totaled
100 W low and 130W high beams....there are many posts on this issue elsewhere on these pages....
What company?
I was so pissed this morning I just posted without searching.
2012 OB Limited, 3.6, AT
Daniel Stern knows all about lighting.
Vince
'00 Legacy OBW Ltd
Vince
Yes, he does but the lack of a link to the information you are referring to does not help as much. Here is a direct link to what Vince referenced: Can I convert my halogen headlamps to HID? Source & More information: http://www.subaruoutback.org/forums/104-gen-4-2010-present/42731-2011-outback-low-beam-hid-kit.html. Great quality pictures on that thread.
If you want MUCH better lighting with proper projectors with out the "squirrel finder" feature, retrofit the Retro-Quik projectors from these guys (The RetroFit Source). Here is a thread about using the system on the older generation projectors How To: Retrofitting Projectors (TRS HID)
Squirrel Finders are the square of light above the cutoff that is visible in this guy's underground garage picture in the "UPDATE" section.). i.e. any stray light above the cutoff is glare for the other drivers.
FYI - light is measure in lumens. Here is why any stray light above the cut-off is bad.
Halogen bulbs are ~1500 lumens
HID bulbs are ~3200 lumes (4300k color temperature)
'00 Legacy OBW Ltd
Changing the projectors too, you will get ACTUAL BENEFIT from your HID's!!
Vince
Yep,
It's refreshing to see REAL advice given on a car forum.
Vince
'00 Legacy OBW Ltd
That is because I am really annoyed and blinded by those that do a drop-in HID system. If you are going to do it...do it right and get most benefit to yourself as well as others.
That's what "winds me up", NEITHER of us can see! your beam runs out so fast and so hard that you can't see very far and I get blinded when I get near you.
The "fart cannon" muffler thing just makes me laugh. 99% of folks do not change the exhaust system so you have this 9" I.D. muffler mated to a 3/8" midpipe and it just sounds silly.
Vince
Vince
After reading through his web site I went with his suggestion for bulb replacement...I put in the higher 65W Osram off road lows and HiR1 high beam. That, I found, was good enough for regular driving.
I am in love with the HIR's! the 2009 Forester had them.
Vince
Meh.
I has wagons.
I'm also using the HIR1 highbeam upgrade. Makes a world of difference.
1 - 20 of 25 Posts
