2012 Outback Wagon
There is a gas smell both inside and outside of car while running.
I have looked around under hood and don't see any noticeable leaks. Anyone have any ideas what this might be?
A couple weeks ago the CEL was on for a couple days, had Autozone check it and it showed I had an emissions leak, think there is any connection?
Thanks for any help,
Tom
Tokyo's between my toes
2001 Wintergreen Outback 5MT
Maybe snoop and sniff around the various evaporative emission control hoses, and take a very close look at the connections at the fuel filter.
Superb Moderator, ,
MY12 WRX, MY07 FXT
I know your vehicle is a MY00, but there was a TSB on WRX's about a fuel line gasket separating slightly in colder weather and fuel smell coming in the cabin. Wether or not that pertains to your case, I thought I would let you know that it may be an o-ring or something. Brian
I have a 99 OB LTD that had a gas smell after refilling tank. The car failed CT Emissions (back when we had it!) and the report indicated the gas cap wasn't sealing. I did not get a CE light, though.
I replaced the gas cap and the smell went away. I don't know if it passes emissions because our state is so screwed up, they can't get the vendor to fix their problems, so the system has been offline for 2 years since my test. I would expect the car to pass now.
The only difference between the OEM cap and the one I replaced it with was the little plastic cable that attached the cap to the car so you wouldn't forget to put the cap back on. The new cap had a punch out for the cable in the top of the cap, but I didn't install it. I think the hole for the cable may have caused the smell problem in the first place.
