Imo the Suspension FAQ bears improvement
I am a new owner of a 2006 Subaru Outback Wagon LLBean with 3.0R H6 Motor, that I bought with 170k miles on it.
It needed shocks badly, as it would bounce up and down repeatedly, lacking any damping, when going over road irregularities, undulations, bridges, and overpass seams.
I read the FAQ where, which recommends Generation 3 front KYB shocks, and Generation 2 rear KYB shocks.
After 5000 miles of being very unhappy with the harsh rear and mismatched damping rates, I spent an additional $300 to replace the Gen2 rear with Gen 3 Rear shocks.
I am ECSTATIC at the improvement in ride quality. There is still plenty of damping, but I no longer cringe, hold my breath, or brace myself, going over irregular surfaces, seams, small bumps, and even Speed Bumps!
I LOVE the MATCHED performance of the Gen 3 rear shocks with the Gen 3 front shocks.
I strongly urge anyone who followed the advice of the FAQ, to replace your Gen2 rears with Gen3 rears IF you feel, like I do, that the back is a bit too harsh with Gen2
Do NOT Be Afraid of some peoples comments that the Gen3 shocks bounce up and down too much. That is definitely NOT accurate with NEW shocks. It IS correct with worn out shocks.
imo, Gen 3 rear shocks got a bad reputation based on peoples experience with worn out shocks. I agree they bounce too much when they are no longer working.
So, I paid for this opinion, and it is mine. I believe it is completely misguided, wrong, and a very BAD IDEA, to mix Gen 2 with Gen 3 shocks. I ABSOLUTELY believe it is MUCH better to use MATCHED shocks front and rear. If you want stiff Gen 2 shocks, then put them on all 4 corners. If you want a smooth comfortable ride, in which the springs and shocks work together to make a pleasant balanced ride, then use Gen 3 both front and rear.
bottom line, under NO CIRCUMSTANCES would I EVER recommend someone use Gen 2 rears with Gen3 fronts.
Im MUCH Happier Now. Especially because I have ZERO remorse about the Gen 3 rears I just had installed, and I will NOT be putting the Gen 2 rears back on unless I decide to go Gen2 in front also.
Pics of foods I eat, cars I drive, and a mug shot
My rear tires wear faster than my fronts
Quicker shifting with Premium Gas
Scenic drives, car pics, and free camping
