2000 subaru OBS limited 189k just replaced head gaskets timing belt water pump good to go for another 100k
hey guys,
is there any performance/improvement to be had with some minor intake manifold work? i was looking around and i found some used intake manifolds for 2.5NA are pretty easy to come by, was just curious if it would be worth it to try? also same for a TB, if not i may still get a new intake to have media blasted and painted, also considering a phenolic intake manifold spacer, i havent done a whole lot of research on them, but sounds like a good thing to add if i will be taking apart the upper part of the motor, maybe a throttle body spacer as well... any suggestions?
thanks much!
thanks much!
