I wanted to share my experience with tracking down the cause of my non-functional puddle/step lights, those little things on the bottom of the front doors of some of our cars.
Today I took a trip to the junkyards to scout for engines >
and while I was there I found some little lens things for the puddle lights on my front doors. My doors haven't had bulbs or lenses since I bought the car, so I snatched them up.
Upon getting home I tried to put in my fancy new LED bulbs and they just would not illuminate, so I flipped 'em and still no-go. I got my multimeter out and started probing the socket... Strange- passenger side, with the door jamb switch in the "door open" position, I was getting around 200mV. With the door jamb switch in the "door closed" position I was getting almost 12V from + to frame, and zero from + to -. I was getting zero with the switch in both positions on the driver's side. Naturally, this is the part where I got online, did some research, and some digging through the FSM. Here's what I found...
There's a little box under the steering column that's referred to in the FSM as an "Integrated Module". The FSM wasn't too clear on its actual location so I wound up removing my glove box & stereo to try & find it. Then I found an article referencing it over on the Forester forum. Apparently this little mini-brain controls all the interior lighting. Once I found it I pulled it and opened it up to discover a beautiful, obviously blown capacitor. I'll be grabbing one of these from the junkyard tomorrow. Attached are pictures of the exterior of the case, and a couple of shots of the blown capacitor.
If your puddle lights or step lights or whatever they're called are not working and you've ruled out the bulb, have a look at this module. It's under the steering column with one blue plug, one grey plug, and one 10mm socket holding the bracket.
