1 - 9 of 9 Posts
2017 Subaru Outback Premium
I replaced the interior bulbs with canbus leds and somehow I fumble fingered it so now none of the interior lights work. Any suggestions? :banghead:
2018 Touring 3.6R
“If it ain’t broke, don’t fix it.”
Maybe a blown fuse? Check the fuse box right in front of the drivers seat. One of the 10A fuses is the one for the interior lights.
1. Pull them all out again.
2. Replace blown fuse.
3. Put them all back one at a time with door open; see which one blows fuse.
4. Repair that socket or bulb.
5. Replace fuse again.
Gee, thanks jimpal! Thanks for the replies Napi and johnre!
2007 2.5 L Obsidian Black Outback XTL
LED bulbs are polarity sensitive. If you plug one in backwards it presents an electrical short to the car and it will pop a fuse. The bulb fixtures do not tell you what side is positive or negative and on some bulbs you can get them flipped around.
'15 Outback 2.5i Premium
I don't think that's right. If you wire an LED backwards, it won't work, but it won't hurt anything either, since it acts like a reverse-biased diode (because that's what it is) it won't allow electric current to flow through it at all. On the other hand, forward-biased LEDs have very low resistance, so they need a resistor in series with the diode to limit the current or they will burn out, blow a fuse, or possibly both.
I think most of the LED replacements for automotive bulbs come with the limiting resistor (sometimes called a ballast resistor) built in, but perhaps some don't, in which case you probably will blow a fuse.
Maybe, maybe not. I've been designing with LEDs since ~1973, and some of them have a pretty low reverse breakdown voltage ratings. Besides a ballast resistor, some LEDs also include a reverse-polarity switching diode in parallel to protect the LED. When I was designing high-reliability circuits, I usually included a discrete protective diode even if the LED was expected to have one onboard. This was back when LEDs were about $2 apiece, and a low-power switching diode (e.g. 1N914 or 1N4148) added less than 5 cents to the unit manufacturing cost.
"Anything worth doing, is worth overdoing."
The red LEDs I got for my puddle lights may go one better. They seem to have something like a bridge rectifier in the package so it will work regardless of the polarity. Either that, or I was extremely lucky and managed to plug both of them into the sockets correctly the first time. What are the odds of that happening... something like 0% given that Murphy's Law is in full effect?
1 - 9 of 9 Posts
