I guess through normal use of the car I have seen scratches/rub marks and such that got on the plastic trim (back of drivers seat, side trim in cargo area, etc). It bugs me excessively everytime I look at it.
So, I found something that Altabrig mentioned down here below
"INTERIOR TRIM SCRATCH SOLUTION
The interior trim on the driver and passenger front doors and the glove compartment were heavily scratched by snow boots and such. Water and rag did nothing. I remembered reading about using a rubbing compound called Scratch Out on interior plastic from a member on PriusChat. The stuff is in a yellow bottle and costs $2.99 at AutoZone - so I gave it a shot. Using a damp microfiber and a small amount of the Scratch Out compound I worked the door, glove compartment, and center console areas for a couple of minutes and then wiped away any residue with a clean microfiber cloth. It looks much better the scratches are 85-90% gone without any hazing. What remains doesn't catch your eye as the scratched out door trim did before every time I opened and closed the door. Sorry, I should have posted before and after pics, but I didn't plan the interior scratch solution as a thread starter."
Is there anything else that can be used to help remove the scarcthes/rub outs, etc? It seems it is so easy to get the plastic scratched up!
