I believe this will be the correct category as most people come here to find information on repairs and how to determine why that annoying light is on. If not, a moderator can move it.
What I would like to have happen here is everyone with smart phone apps that connect to OBDII via a wireless or bluetooth interface to post what they have, how they feel it works and would they recommend it to other members as a viable tool to use in retrieving codes, watching and/or recording data, graphing capabilities, exporting, compatibility with different vehicles, years and models.
If you want to post the cost, do it. A lot of members need to know what options they have.
This could be an excellent reference point. I get a lot of inquiries about this, but I can't check into every option available. Strength in numbers as they say. So post away.
Attached are screen shots generated on my iPhone using Innovate Motorsport's OT-2 interface and the iPhone app. It is a run I did to show someone else how it works. The interface is wireless or hard with a data cable. So it can work either way. The cost was $180 for the interface and the app was free. Information can be viewed on Innovate Motorsports OT-2 - Transform your iPhone or iPod into a wireless gauge, data logger, dyno, efficiency meter and OBDII scan tool.
It is a good tool to have as it has a lot of features.
The first is the graph and pics 2-4 are from a different window giving lapsed times and g-force.
Speed, G force and HP calculations are based on data using the accelerometer built in the phone. On the phone, I can slide a bar to specific areas of the graph for combined info at that point. You will also note that in the upper right corner it gives max speed (up to point the stop button was touched) and 0-60 time. Mine is 8.53 seconds. **** quick for an Outback, heh?
Max HP, as logged on the phone was 184. I don't think its correct, but I wasn't logging on my pc at the same time to compare data. I haven't tried Using the OT-2 to connect to two devices at the same time yet. I'll test that when I get the car back from the tranny shop.
Data parameters can be chosen when you connect to the car and can also be graphed in the data logging software. The graphing is what is most helpful. Especially when someone needs to see a waveform. All the graphs can be exported and texted or emailed in .png format.
