1 - 10 of 10 Posts
2002 Outback, EJ25 Engine
Just changed the oil in the rear Diff, car has 103K and finally noticed after draining the it first that I had 85W-140 Synthetic Gear Oil. I had to put it in of course, so do I leave it in or change it for 85W-90. Thoughts? Thank you
Tony
2005 LL Bean
Tony
It's a bit on the viscous side, but I think it'd be OK. I wasn't paying attention when I bought my fluid and ended up using 75w140 syn in the front. I know it's very common for other applications to switch to a synthetic of that weight. I also imagine that the wrong weight, but clean is better than what was in there. Just change it the next time you are doing maintenance.
Wonderful, I will leave it for a bit, BTW how do you fill up the front diff, I did not see a fill plug like the rear so I did not drain it. Of course I will go and exchange the 85w-140 for the proper 85W-90. Thanks for the quick response.
2005 LL Bean
I'm not sure on that model. Mine fills right through the dipstick hole. You should be able to find a PDF of the owners manual (and svc manual,ost likely) that will show you.
Thanks, I will look it up, the ALLData site says to fill it through the gauge hole which might mean the dipstick.
2011 Outback Limited/2.5L/CVT
Yes it's much too thick. Even over the road trucks run 75w-90 synthetics now in order to save on fuel.
I say he's ok. If the first number was higher than recommended and or the last number lower, thats when problems will occur.
It's not going to cause any wear related problems. But using much thicker lubricants than required in the engine or driveline does reduce fuel efficiency. I see people running 15w-50 in non-turbo Subaru's, which is just nuts if you don't drive in the Sahara Desert.
I have a 2002 subaru forester. I am looking for the 85W gear oil recommended for both rear diff and the manual tranny. Where can I buy that? I can find 85W-xxx but not just plain 85W. Thanks. james wagner [email protected]
Dixiebooks,
You can use a 75w-90 synthetic in place of the 85wt. Just make sure it's a GL-5 rated product, which is necessary to properly lubricate the hypoid gears.
TS
1 - 10 of 10 Posts
