1 - 9 of 9 Posts
Hi,
I am new 2019 outback owner, I recently purchased a Yakima Skyline roof rack system, I was not aware that there were factory bars that came standard (I know pretty dumb). I installed the system and I do like the look of it on the car.
Where I a struggling, now that I realize there are factory crossbars, is there any real benefit to having the Yakima system? Do people dislike the factory system? Do you think I am better off for having the yakima system in any way(noise, load capacity, etc.)?
My long term concern is when I put a lift on the car of 2 inches, i will have hardly any clearance in my garage. I suppose at that point I could sell the system and use the factory cross bars at that point. Curious to hear your thoughts.
thanks,
MB
2017 Outback Premium, silver
An aftermarket crossbar is going to be about 4 inches added to the vehicle height as compared to the stock crossbar.
The stock crossbar gives you about 39” of width, vs a typical Yak or Thule cross bar width of 50”, thus you can put more crap on an aftermarket, your call as to how useful that is.
I use a Yakima system as I don’t like the angled design to the stock bars that has bikes mounted on trays, leaning towards the outside of the vehicle. My bike trays are the type where the F wheel clamps, as opposed to newer designs that grab the in place front wheel. That design, such as the Yak FrontLoader likely would better support a bike mounted on a slight angle.
Wider bars have uses, do you use a canoe ?, would be a tight fit on a 39” wide bar.
476280
Wider bars have uses, do you use a canoe ?, would be a tight fit on a 39” wide bar. View attachment 476280
thanksthat is helpful. I really didn’t even think about the extra 11 inches I’ll get in width using the system. I also have 50 in. Bars. I like the flexibility that comes with for bigger items I may want to haul on the rack.
I just did the math on my garage and even if I lift you car 2 in. and put a cargo basket on it which has a 7 in height I’d still clear my garage by 3 inches or so.
it looks pretty **** clean and it’s relatively short money, I suppose I could also sell in the future if I had to.
476281
Yakima is stronger more solid mount especially if you are ever going to mount a roof top tent. I actually went with 55” HD bars on my 2019 Outback.
That said I hate the added height and that you are limited to using only the front two crossbar slots. Yakima, there had to be a better way to do this. However, between Yakima and Thuke Yakima is clear winner.
Reactions: mbreen813
Green 2020 Touring XT Outback
The added height might give you more clearance for long skis on the hatch, too. So you don’t have to put them in tips to the front or risk scratching your hitch. Idk if this is an issue still waiting to take delivery of mine, but it is an issue with the factory bars on the Equinox my Outback is replacing.
so you can't use the rear slot option on the crossbar setup, huh? I was wondering if you would be able to get more crossbar spread than the 30.5" that the yakima offers. I want to put a 3-person RTT on my car and Tepui recommends a 32 -48" spread for their 3-person tents. I've seen a lot of people mounting the 3-person tent to the roof, so I guess it's just a liability concern on their part?
would the added height of a roof rack and RTT affect my center of gravity in a dangerous way?
Nope. Not with the Yakima Skyline + Landing pad system.
I have voiced my opinions on manufacturers ratings on here several times. Basically, I think they are BS and written by lawyers. I’ve had Jeep with roof rack and Land Rover Gen1 Discovery with roof racks. Both were loaded to the hills and both were on lifts and 33”+ tires. Never a problem.
The Yakima system is pretty solid for over the counter bolt on. If you need wider spread I thing FrontRunner rack uses the tie down points not sure if that will give you spread you need Or maybe you might be able to add the 3rd rail using OEM crossbar and Yakima OEM crossbar attachment hardware and the Yakima Skylines on front two.
Eh, looks like crap. The LockNload on SL mounts are better but no reason it shouldn’t be 3” lower. FrontRunner does it Prinsu does it too :rolleyes:
2010 Outback 2.5
My thoughts on Yakima vs. Factory set-up.
Yakima Pros:
Any Yakima bar type is more rigid than the factory crossbars. Those things will flex like a trampoline if you have any sort of load on them.
You can go wider than what is allowed with the factory bars.
The added height allows you to place a snowboard upside down, without the bindings touching the roof.
The added height allows more clearance for the rear hatch to open with longer items on the roof.
Flat surface vs. convex surface on the factory crossbars.
Yakima Cons/Factory Pros:
The added height (& bulk) of a yakima system increases drag and reduces fuel economy. No matter what sort of fairing you have, it will create some wind noise.
Cost. You're looking at $400+ (new) for just a base set-up with no accessories.
Even with the most expensive Yakima options, you are still limited on bar spread.
In short, I think the fold away design of the factory racks is pretty decent engineering, but with some re-design and different materials, it could hands down be the best factory rack in the automotive industry.
1 - 9 of 9 Posts
