1 - 12 of 12 Posts
Hi,
I looked through the Outback manual and all it says is that the hill holder function may not engage on gentle slopes. Unless I missed it somewhere else in the manual, would anyone know if there is a particular slope angle at which the hill holder engages the brakes?
Also, I thought I read in another thread that the brakes had to be depressed quite a bit (like a strong push on the brake pedal instead of a gentle touch) for the hill holder to engage. Can anybody confirm this?
Thank you.
2015 Subaru Outback 2.5 Limited Eyesight Lapis Blue Pearl
It turns on for me on most hills, and I don't recall having to press the brake harder than I normally would to stop gong up a hill. I do love in an area with LOTS of hills, and can honestly say that it's nice to have. It's also very much needed since the CVT does odd things on a hill. When backing down out of a parking as spot, without the hill holder the CVT behaves sort of like a manual if you aren't careful about holding the break down until it "revs into gear". Having the car almost roll into traffic convinced me to just leave the hill assist on all the time.
2010 OB 3.6R limited
Sorry for hijack the thread.
Is it safe to turn on hill holder when car is moving?
When hill holder is engaged(parking brake is on), will the brake light in the rear turn on?
It seems to be, but HillHolding™ is an experimental science.
Looby
13 Outback 2.5i Premium w/AWP 6MT
I remember reading in the spec somewhere it is roughly 5 degrees of hill in both upward and downward directions.
Tungsten 2017 2.5 Limited w Eyesight SOLD!
It is safe to engage when move and a green indicator light comes on. I use it on boat ramps and it works well enough. Just buckle in and step on the gas and off you go....YMMV
I've seen posts about adjusting clutch sensitivity and hill holder but is there a way to adjust the sensitivty of when the Hill Holder kicks in (engages)? In other words, can one adjust the slope angle at which the hill holder gets triggered?
I saw a post where somebody said the hill holder was kicking in on flat ground and another post where the hill holder required steep slopes.
Gen4 and newer are electronics tied to the parking brake. Older versions are mechanical and tied to clutch use.
The Gen4 and newer the hill holder - pretty sure will even activate without touching the brake. I have had it kick on where I coasted to a stop on a hill in SF with it turned on of course. Turning it on when you moving is the way it was designed it won't actually activate the brake unless your stopped and on a hill. Yes it works with the car pointed down hill or up hill. Which is nice for those of us who parallel park on steep hills like say SF.
2017 Outback Limited 4 cyl.
Yes you can turn it on while in motion. I have the same question about brake light, I assume it is on..
The parking brake does not illuminate the brake light... it's a separate system from the hydraulic brakes, so that light isn't tripped. The hill holder button / function doesn't modify that behavior.
1 - 12 of 12 Posts
