Gang,
I purchased some rallitek end links about 6 months ago, and finally am getting around to installing them.
After jacking the car up, and setting it on stands, I sprayed the bolts with WD-40 to loosen things up.
As I started to loosen the bolt i noticed that the entire assembly was spinning (the bolt and the housing that feeds into the endlink.
Any ideas on how to solve this issue?
thank you in advance as always!
