One thing not mentioned is, on a roller dyno, how much the flexing of the tire contact patch and sidewalls takes up in HP to get the tires to conform to the roller - different tire constructions will yield different results, even when the tires are the same diameter - or more correctly, loaded rolling radius.
Jalopnik is also a bit confused about physics, and misunderstood Jason Fenske in the Engineering Explained video that he linked.
If wheel diameter alone determined power delivered to propel a land vehicle forward, this experimental TGV certainly would not have attained the world's fastest rail speed at 574.8 km/hour:
https://en.wikipedia.org/wiki/TGV_world_speed_record
Note that they increased wheel diameter from the TGV Lyria's stock 920 mm to 1050 mm in order to improved overall gearing and keep electric drive motor speed reasonable.
not mentioned in the main article.
braking distances increase with more spinning mass on the wheel/tire.
