I've searched around and could not find a post.
During highway speeds and cruising, (55-70) Once and a while I can feel a jump or jolt, it feels like a transmission slip. Though I'm not sure if it's one of the differentials. It's enough to let you feel it, but not enough to shake the entire car. I haven't noticed it with a shift, however by the time you look at the RPM the event is already over.
2011 Outback CVT, 90k miles. I have not done a CVT flush, thinking that might be my issue. Although when I bought the car at 54k, it had irregular tires, not sure how long they were mounted, which makes me think could be a differential issue.
Thanks for any insight.
Sent from my Pixel using Tapatalk
2013 BRZ 2005 OBXT
Deff could have some diff. damage then depending on how long the car was run like that. I went to look at a used car and it had that same tire situation going on. Price was a good price and all even if the diff was shot but I just told the guy no thanks without even test driving it. He asked why and I explained why to him and how he would have a hard time selling it to someone that was knowledgeable unless he replaced the other two tires as well with the same as the fronts.
03 H6 OBW & 06 WRX Sportwagon
any jerking/bucking/grabbing or unusual noises when maneivering in tight turn or circles in parking lots? try tight circles on dry pavement.
When I saw the title jump at highway speed I thought you had figured out a way to make the jump to light speed :jump:
