1 - 7 of 7 Posts
So when I bought my 05 OB it didn't come with any key fobs. So I've been searching to see what one I need. I found a 2 button one and a 3 button one. So do I need the 2 or the 3 button? Does the numbers on the back matter to what one I can pair with my car or not? The site I took the screenshots from don't have the 2 button one listed so I'm assuming that I need a 3 button. Noticed the Fcc numbers are different and so is the Pn. So thats why I'm asking before I waste money buying a key fob that won't work.
484512
484513
The AG000 is original to my 05 OBXT (3-button with the large half-moon style). It's likely giving you multiple choices (Country of Origin differences?) but with the same FCC ID as the cases can be different, but use/transfer the internals.
Here is where its located in my 05. It took me a bit to find it after I took the glove box out. It sits right where I'm pointing to.
484601
484600
2008 Outback wagon, 2.5i Touring
4 buttons has the annoying panic button the back
my car is a 2008, first year with the key fob builtin
I found a 2007 regular fob in car at the u pull yard and it works fine
programming is easy
I pulled out the keyless entry module. It says what FCC code it uses. So now I know what ones to get.
484654
1 - 7 of 7 Posts
