1 - 20 of 30 Posts
Is there a way to silence or shorten the "beep when using keyless entry? One beep is fine, but the four when unlocking all doors is a bit excessive.
2018 Outback 3.6R Limited Magnetite Gray
Electronic chirp when lock/unlock with remote - To turn off chirp or to turn back on
1. Sit in the driver’s seat and shut all doors and the rear gate.
2. Press the “UNLOCK” power door lock switch.
3. Insert the key into the ignition switch.
4. Hold down the “UNLOCK” switch, pull the key out and re-insert it into the ignition switch at least 5 times within 10 seconds after performing step 2.
5. Open and close the driver’s door within 10 seconds after performing step 4.
6. When completed the turn signal lights flash
2012 Impreza Sport Ltd 2013 Outback Limited SAP
Keyless entry, I would assume is part of the SAP. Normally indicating that one would not use a key in the ignition. Do you have a SAP?
No SAP. I believe creso's comments will work. I'd prefer to keep the 1 chirp, but I think I'd rather have 0 chirps then 4 when I unlock all doors.
Thank you for your help! I'll post again after I get a chance to try this out.
2013 Subaru Outback 2.5i Premium CVT
I've been trying this same sequence all week with no success! Am I doing something wrong? Or is it a different procedure for the 2013 model? I checked the manual and all it says it to contact the dealer!
This worked for my 2013.
'14 3.6R Outback
creso, you followed the steps exactly??? I wonder what I'm doing wrong?:confused:
Don't feel bad I can't do it either. I had trouble with the seat belt chime disable too because I was going too fast.
Not sure what you are doing wrong. This same procedure also worked on my 2012 & 2010 Outback.
I suggest taking it to the dealer to have them make the change with their OBD tools.
OBW CVT MY12 SWP
I believe that Step 2 should be:
2. Press and HOLD unlock door switch
3. Insert key
4. Pull key OUT & re-insert it 5 times
5. Open and close driver door.
At least for me, I had to hold down before proceeding to step 3. I wanted to re-enable the beeps.
'14 3.6R Outback
3. Insert key
Holy crap. I don't know what I did right but this worked... after trying like 5 times.
Thanks!
2013 2.5 Premium
when I had the viper 4204 remote start installed, it's fob unlocks all doors with a single beep, so I stopped using the OB's buttons. Viper FTW. :)
3. Insert key
YES!!! FINALLY!!! Thanks simnorm! This sequence worked for me! OMG this thing was driving me NUTS for days!
2012 Outback 2.5 Premium CVT
Worked on my 2012
Worked on first try on my 2012. Glad I found this thread I have been wanting to silence the beeps from day one. Thanks!!
Does this just silence the opening beeps only or does it silence the locking beeps too pls?
Is it possible to silence just the opening but not closing pls?
Thx
3. Insert key
'15 STi and '13 GTI
I also find the 4 beeps irritating on my '12. Unfortunately you can only silence it completely for either lock or unlock, there is no further customization.
2018 Outback Touring 3.6R
LOL -- I wonder what engineer came up with that sequence! It's sure not something that someone would do accidentally.
1 - 20 of 30 Posts
