1 - 7 of 7 Posts
05 XT
Hi, Does anyone know what kind/style/name of the battery that is in the keyless remote?
Thanks alot
Will
'04 Subaru Impreza Outback Sport H-4 4EAT Platinum Silver Metallic
Good, a common type. ;)
Checked mine and it's the same.
My graphing calculator uses four of those. Computer mainboard does, too, for BIOS.
Just curious...how long did the original battery last? And how did you know it's failing? Reduced range? Or just quit? Is there any re-programming required after removing/replacing the battery?
Thanks,
05 XT
I noticed because now i have to be like 5 feet away from the car to open the doors. Before i could go from inside the house and you could see it beep in the garage.
2016 Subaru Outback 2.5i Limited w/Eyesight
I replaced my CR2032 last week because of very short range performance. I lasted about 2.5 years. Now with the new battery, operating range improved. After I replaced the battery, I was unable to unlock the doors... But after I had the driver's door opened once, the remote control started to work... kinda weird hein?!
I thought it would need reprogramming (resetting?), like after the car battery is disconnected.
When I reset the ECU by taking the negative terminal off the battery I got into the car, closed door, put key in and turned it rapidly from lock to on and back again 10 times within 15 seconds, as per the owners manual instructions.
Guess maybe the keyless thing itself just needs a one-time signal back out from the car, which probably happened when you opened the door.
1 - 7 of 7 Posts
