1 - 11 of 11 Posts
Hi everyone, I have a 1999 Subaru Impreza Outback Sport. For a little while now, my car has been running really badly when it gets wet. I assume it's an o2 sensor. Whenever it rains, I go through a car wash, or just whenever the car gets wet in general, my car throws codes like crazy and it runs horribly. Anything I can do? Thank you!
If you don't tell us what codes you are throwing, we can't help much.
I could be wrong but I don't think the 02 sensor will cause erratic behavior like you are describing. Mine would occasionally throw the dreaded P0420 when I was driving in heavy rain but it never affected the performance - well, maybe just a little, but hardly noticeable.
Maybe you have water splashing up on the coils (I don't know if your's has plug wires - my car only has individual coil packs) or plug wires...
Can you get your hands on a code reader?
Present your data and somebody on here will help!
Oh yeah of course, sorry. It gave me a P1325 for a knock control limit in cylinder 1. Thank you
things that get agrivated by dampness:
knock sensors,
engine grounds.
old plug wires, (if buying: subarus like NGK plugs and wires,...everything else you buy aftermarket gives problems).
knock sensors,
engine grounds.
Hmm okay, thank you. I just replaced the plugs and wires about 2k miles ago, should I check the knock sensors?
as you got a knock sensor code = p0325...p1325 ?
yup, both the knock sensor, and its wire harness.
Aaah okay, thank you. Any advice? Should I buy a new harness?
I never did one on a subaru, a 99 2.2 should be pretty rudimentary though.
will update title, plenty of knock sensor discussion here though.
(updated title).
Coil pack (as mentioned in an earlier post)?
Anywhere there's high voltage, dampness and moisture can cause arcing, leading to misfires.
Discussion Starter #11
Update: it was indeed the knock snesor. Bought a brand new one earlier and it runs perfectly in the rain now. Thank you everyone!
1 - 11 of 11 Posts
