Stock ride height
Stock ride height
In progress
Stock parts removed, note those fat OEM rear self-leveling shocks
Front Koni inserted (Using EDM Legacy 2.0R OEM front strut body. The spring perch is 3.5cm lower than EDM Outback Strut)
Currently stock Outback 3.0R springs are used, may change to STI pinks later...
Rear Koni for Legacy "converted", note the two new grooves to hold the spring seat.
The rear suspension is now 3 way height adjustable (no more saggy butt, currently the middle groove is being used)
Bright Taxi Yellow Paint, I did it myself...probably not worth the effort IMO...all that work just to snap this picture...
JDM S402, yes, its from a S402!! rear suspension trailing arms, fro one of 402 Subaru S402s ever made in the world!!! (PS: they are identical to Spec B units anyway)
JDM Legacy GT Spec B aluminum from control arm with JDM ZEROSPORT LCA bushing installed
Toyo T1-Sport rubber 225/40/19...replacing much loved Goodyear Eagle F1 Asymmetric 245/40/19, used less than 10K miles because they rub after lowering :/
Looks like it now means business
About 1.5 inch drop after
Lookin Pimp!
