'05 OBXT Stage II+: Cobb AP, Grimspeed UP, Invidia DP, AVO TMIC, Grimspeed MCB, '05 KYB's All around w/ Rallitek Overload Springs, Rallitek F/R Sway Bars, AVO Endlinks, STI Gauge pack, Perrin CP, Hex
I have an 05 OBXT and bought 00-04 KYB Excel G Struts all around with Rallitek Springs for the rear. I don't have the tools or the time to do the install so I paid a shop to do it only to be told that the 00-04 fronts are too small and won't fit on my car. The Fronts I ordered are for the 04 Outback KYB334447 and KYB334448. Did I order the correct parts or is the shop forgetting something?
Thanks for the input.
Fresh Out of Outbacks!
Ouch, wish I could help... I used the 00-04 struts on the rear of my 06 and they significantly improved handling. No fitment problems. I did that because the original struts were underdamped. I never had a problem with the way the OEM fronts felt, so when it came time I used the KYB parts for 05-09.
I've only heard of the rears going to 00-04. The fronts most people use the stock 05-09. You might not get an answer.
that's weird, i would have never guessed them to be different....i was just about to buy 05-09 fronts for my 02 or 03 OB's...guess I'll hold off until I find out the difference.
2005 OBW 2.5i, 2010 MB R350 Diesel, 1991 Toyota MR2 | suspension & braking enthusiast
KYB334448 and KYB334447 are the correct front dampers for the 2004MY and they will fit the 2005MY no prob. Are you sure they shipped the right ones? Did they come pre-built with springs as a complete unit? If so you need to remove the 2004 springs and install the 2005 springs/top mounts.
What did the shop actually do? Did they disassemble the old 2005 dampers and try to put the springs onto the 2004 dampers or did they not even attempt that cause the dampers looked different? (they do look different btw, but they are compatible.)
Don't get the 05-09's for your 02. Get the ones designed for your car - they are a few dollars more expensive, but are better.
