2018, Outback, 3.6R Touring
As the title suggests. What is the largest tire I can put on my stock 2018 Touring? The Duelers are shot at 60k mikes and will be replacing them asap. I would like to go wider/larger if it makes a difference and wondering how big/wide I can go without rubbing at all
Thanks in advance!
Supporting Vendor
Tire & Wheel Specialists
Good afternoon,
Few fitment options however you may want to measure on your vehicle from the stock tire to determine if it would interfere with anything. 245/55R18(28.6") should fit - same height but 3/4" wider. 245/60R18(29.57") would be 1" taller and 3/4" wider this may rub though. Ill send you a PM, we would love to help further.
Once you change tires from the OEM you will likely see a MPG drop already then if you go wider or taller etc that usually means a heavier tire with more rolling resistance so dont be surprised if you see a 3-4MPG drop.
