1 - 20 of 28 Posts
2011 2.5 CVT with lpg
Been chasing a front end rattle, changed sway bar links and bushes, inner and outer tie rods with no success. Checked the rearmost bush in the front control arms and found a good half inch of vertical movement on both sides. Zero movement front to back. I guess these bushes are designed to give a little but how much movement is acceptable?
2017 Outback, 2.5L, Auto; 2018 Forester, 2.5L, Auto (for Mama); 2005 Baja, 2.5 Turbo, Manual
I don't have a spec number for you, but that just doesn't sound right. You'd best get it checked by a real mechanic.
2013 3.6R Limited
Red Subaru,
Note that the OP is from the UK. In that part of the world, the correct terminology is indeed "bushes".
Now, back to our regular programming.
Reactions: traildogck
Ok thanks guys. Gonna get it checked, just thought that if the movement I'm seeing was not normal, I could have got parts first and just got them changed. Sorry about the bushes/bushings thing, at least I didn't mention pants or fannies, then we'd really get confused!!
Master Caster
🖤💔💙 3 Beautiful OBXTs
I am happy that you "got it sorted". No reason to mess your nappies over it.
I hope the bushes were checked with the car in the air. 2nd, fore-aft movement is very hard to effect. You need a large impact (or crowbar) to simulate a wheel impact in those directions.
1/2" sounds like a lot. More than my car and I am replacing with these this weekend. I am excited to see what these are like. I have utilized several aftermarket bushes, and these are a new design.
Discussion Starter · #10 ·
Those look interesting traildogck. I will probably just get the standard ones plus the ball joint as well, may as well do them all.
Don't know what the nappy reference means?, but thanks for the help.
Master Caster
I don't understand how I messed my nappy/ diaper?
You didn't...
I am Pennsylvania ******* ... My ignorant *ss was just throwing out all of the odd phases I know from the UK.
I don't know how to phonetically spell...shed-duuuaaael. Or I would have incleded that also. But I guess sked-ul makes less sense. That's the best I have on both.
Discussion Starter · #14 ·
Sorry traildogck, no offence meant or taken. Being Welsh I too am probably the UK equivalent of a *******, and proud of it !
2011 Outback Premium 6spd
What part number did you end up getting for what year?
I put 16-303's in my 2011 OB and the clearance on the bolt was just a little more than stock and I can't stop wondering if I bought the wrongs ones or what.
Seems to ride fine but I can't get it out of my mind and I don't want to get it aligned if I need to do it all over again. :crying::|:|:|:|
Discussion Starter · #17 ·
I bought aftermarket standard bushes/bushings. From 2005 on through to 2014 the parts are the same apparently. Had them fitted today and the rattling I was getting on uneven roads seems to be much reduced though I haven't been far. Fingers crossed.
Discussion Starter · #18 ·
So......replacing the rear bushes on the front LCA has quietened the noise significantly, but it's still there. I am going to replace the other bush and the ball joint as well now, as this seems to be the area the noise is coming from. Should have done them all at the same time really, but I've been chasing this noise for a while, replacing parts to no avail, so was trying to keep wasted parts to a minimum.
2011 Subaru Outback 2.5i Limited
How were you moving the control arms around? With your bare hand or prying on them with something?
I'm excited to see what you find as I have been chasing a rattle - maybe the same one.
1 - 20 of 28 Posts
