1 - 15 of 15 Posts
2015 Outback 2.5 Limited
Hi Guys,
First time poster here. I'm considering installing a light bar on my '15, and wanted some advice on mounting options. I like the LP Adventure small bumper guard, but would prefer a more streamlined look. I'm unable to post an image but can provide a reference if interested.
I like the mount in the lower grill area, however I wasn't sure how that was installed (directly to the bumper?) or if that is the best spot as far as functionality goes. Any advice would be greatly appreciated. Thanks for reading!
2016 2.5i Outback, 2002 Audi S4 Avant, 1980 CB750F Supersport, 1985 Carrera 3.2
SSD Performance light bar is cleaner looking in my opinion and high enough that it doesn't blast a lot of light on the ground. Had one on my last STI and it worked great, both mounting wise and aesthetically.
I came across this one as well, definitely another good option. How easy was the install? Thanks for the reply!
You'll have to take off the bumper and do some minor drilling on the bumper support but it's actually quite easy to do. What I liked is that the bar actually mounts to two tabs. So if you aren't using the lightbar you can quickly disconnect the light and two 19mm bolts to remove the assembly, leaving just the two mounting tabs hidden back in the grill.
So far so good. Though I'm never going at speeds where I'm afraid I'll outrun my lights. My roof bar is there when I want to look at stuff in the tree line.
Sent from my Pixel using Tapatalk
Gotcha! Any recommendations on specific bars/brands to look at? I kinda want this to be my only extra light set-up and would like it to be sufficient all around
Sounds easy enough, although I most likely won't be doing it myself (I'm not very handy at all). So, the individual components can be removed fairly easily?
2015 Outback 2.0D
One option...
https://imgur.com/a/zxSRw
This bar does not blind me even with white snow on the ground, it has very little light to near.
Vertical spread is narrow, but horizontally is wide.
Because of low install height, i can use this at quite heavy blizzard and dont have just white wall ahead of me.
Discussion Starter · #11 ·
One option...
That looks really great. I'm concerned that if I went that route, the front license plate will be partially covering the lights.
Which set are we talking about? I’m looking at a 20” too.
1 - 15 of 15 Posts
