1 - 2 of 2 Posts
Hi everbody, I have a problem with the taillights on the 2010 Subaru outback. The left taillight illuminates less than on the right side and the lights on the left side of the boot lid do not illuminate at all, including the left license plate light. I checked bulbs and fuses. The left turn signal and left brake light work. Thanks a lot from the Czech Republic.
Automotive tail & brake light Vehicle registration plate Car Vehicle Tire
2012 OB , 2017 Impreza
have you tried swapping the bulb between sides to make certain it is not the bulb?
(i assume you are looking at the bulbs in the hatch ....not the outer ones in the fender)
if this does not help, you may need to pull off the upper plastic on the inside of the hatch and inspect for broken wires near the hinge area. (where the wires flex)
1 - 2 of 2 Posts
