I have a 2016 and the lift gate beeps four times while opening. After it goes all the way up it drifts back down about 4 inches, this is not the memory feature since it goes all the way up first.
I wonder if it is telling me I need new support cylinders? I have never had those, what I call struts, go out that fast but that door is pretty heavy.
My question is, does the 4 beep signify that there is too much load? That would make me think that it is a strut issue.
And if so is it the support cylinders I need and not the position sensor?
Does it do this all the time? Have you force by hand while opening?. I would try resetting the height adjustment then try again.
Laughing at Oneself and with Others is Good for the Soul
When using the FOB it is normal to hear 4 Beeps and 2 Beeps when switch on the gate button.
2015 lift gate goes all the way up then drops 2-3 inches then beeeeeeep
tried everything called dealer (45min away) been doing it for over 6 months
thought it was the memory button or setting
dealer helped me reset
final:
THE BEEEEEEEP IS A WARNING FOR A DROPPING LIFTGATE
BEEPS THEN STOPS TO PROTECT FROM GETTING CLAMSHELLED LIKE MY SIENNA DID ME
SOLUTION: NEW SUPPORT STRUTS
GET REPLACED MINE UNDER WARRANTY
NO MORE BEEEEEEP AND IT FULLY GOES UP
tried the non power lift gate on a new cross trek VERY EASY TO UP LAND DOWN hmmmmmmmm maybe don't need on my NEXT subaru
wife loves this car
now its training car for my 16 daughter safe safe safe great visability
2015 Outback 2.5i
Yeah, I could have done without. Not sure by then you'll be able to get one, though.
