Hi! I would appreciate some help locating primary source of oil leak on my 2000 H4 Outback.
It has 130k miles and leak is not bad yet. I can run between normal oil changes without topping it off. But when I look from underside, oil is everywhere. Both head cover gaskets and head gaskets are wet. Most of the oil seems to collect to the back side of the oil pan, and rear pan bolts are really dirty. Does it leak from the pan gasket too or oil is just pushed there by airflow? Or is it rear crankshaft seal? Hope not!
Thanks!
Thanks!
