I have been locked out of my 05 wagon (my son's).
The remote would not unlock it so I put a new battery in it, still nothing happened! I did notice that there was no flash from the indicators when I pushed the remote to lock or unlock.
I tried the key in the lock to manually unlock it , but although it turned , nothing happened!
I carefully used a strong wire to slide through the door seal and pulled the internal handle back but this did not work while in the locked mode, as the door still would not open.
My next attack is to use the wire to activate the lock/unlock switch on the driver's side door to see if that works.
Any other ideas out there if that doesn't work????
