1 - 8 of 8 Posts
1996 Impreza Outback Wagon 2.2 -- over 200K miles.
Hi, All -- I just joined today. Hoping to learn a lot about Subis!
I've enjoyed my '96 Impreza wagon 2.2 for 16 years -- many miles of trouble-free driving. Recently it gave me a bit of trouble when the speedometer stopped working. My mechanic says I need an output speed sensor (VSS) -- it's the sensor attached to the transmission. Can't find one new or used -- does anyone have thoughts on where I might find one?
2006 WX8, 2022 BWA
There's no sensor. The speedometer is cable-driven. There is a reed-type sensor inside the speedometer, used by TCM and cruise control. But it may still be a broken cable adapter threaded into the differential case.
RE: Need VSS
Thank you for your response. One day after the speedometer/odometer stopped working, the check engine light came on. When my mechanic checked the cause of the warning light the message was that I needed a VSS. The car is an automatic -- does that make a difference? So....if I need a cable adapter instead, are those hard to find as well?
if this is true, (and it is not true for the 96 legacy,) then the speed sensor is actually part of the speedo.
and your problem is likely a busted speedo cable.
or maybe the sensor in the speedo, but this is a distant 2nd.
or the speedo gears in the front diff, a very distant 3rd.
Thanks to all for your helpful replies to this thread. Based on your feedback I tried a new mechanic for a second opinion on my speedometer problem. All who said it was the speedometer adaptor are the winners!! I'm happily back to knowing how fast I'm going and racking up the miles toward 300K. Thanks again!
1 - 8 of 8 Posts
