I didn't think a 2010 blew head gaskets. My Gen3 2008 had more of the common weeping headgasket which simply weeped oil out the side and did not compromise the combustion seal.
Your problem might be more of a cooling system problem than a headgasket. Are you sure the fans are running at the right temperatures and right speed conditions and A/C settings?
You might want to get a combustion chemical test kit to check for exhaust gases in the coolant.
