2003 LL Bean Outback H6 and 2019 Outback Base
I have replaced the IAC valve ,the TPS, ALL new plugs and still idles at 350 to 400 once warmed up in Drive. In Park ( once warmed up) its idles at about 400.
Any ideas why idle so low?
It also acts sometimes like its " starving" for fuel. Maybe the mixture/ airflow is off ?
Thoughts? ALL Subaru parts
much appreciated
much appreciated
Are you sure that's really where it's idling? The tachometer is very misleading in these cars. What does an OBDII scanner say it's idling at?
You do have a fuel filter under the hood, so you could swap that out. On a ten year old car, it can't hurt. You never know--it might be plugged up a bit.
I will inspect fuel filter....idle rough as well. When fan is on and radio........idles at 650 ish in Drive.
Thanks for the info
I will put scan tool and get accurate speed.. Thanks jp1203....
