Greetings,
2005 Outback 2.5i - 96,000 miles
I've had a similar issue as others with cracked/disintegrating lower control arm bushings causing a "thudding" sound. The dealer initially diagnosed the problem as the bushings and also suggested replacement of both ball joints due to wear on the ball joint boots (Quoted $590 for bushings, ball joints and alignment).
I checked the issue with an independent mechanic who concurred with the bushing replacement, but said the ball joints were fine. They suggested replacing the lower control arms instead of just the bushings (Their quote was $650).
Looking for opinions on what route I should take. Does it make more sense to replace the full LCAs instead of just the bushings? Any input appreciated.
