1 - 8 of 8 Posts
1997 Legacy outback
Is is Possible for me to use Lowering springs for a regular legacy wagon on my legacy outback? If not, then what are the differences in the suspensions? I have seen some products labeled "Not for Outback" and I am wondering why I cannot use these. what should I do?
Superb Moderator, ,
MY12 WRX, MY07 FXT
Actually, to get another inch of height off, can't you just put Legacy springs on your Outback? Like my OBS, I can put 2.5TS or RS springs on to lower my ride height. Maybe? Brian
1997 Legacy outback
I found an Intrax lowering spring for the car that says it will lower it 1.5 inches has anyone tried these springs? Will that give my car a nice look with some 17 inch wheels? any help would be appreciated.
Hi, I don't mean to sound critical in the slightest, but why buy an Outback and then lower it rather than buy a (cheaper surely) Legacy and then lower that if you want?
Cheers,
Karl
1997 Legacy outback
The outback was free except for registration, I just needed to replace the blown head gaskets
And you can't beat the fog lights up front
MCMXCVIII BGVI EJXXV
Whiteline makes Outback Specific lowering springs, however I would think you still need to run with aftermarket wheels. But the again, I would hav eno idea how the OE struts would perform under the given ride height.
-paK +1
2000 OBW (Black) 2.5 N/A, Borla Header, Apexi Noir Exhaust, HID in head lights & Fogs.
I have been coming across the same labelling. I am looking to lower my 00'OBW this coming spring and I have no leads as to where to go to buy the parts.
Anyone help with my search?
2005 Outback XT GRP
Legacy lowering springs will work on the Outback. The only difference between the 2 suspensions is that the Outback has a longer strut body and longer rear bumpstops.
It's actually very common to see people swapping the 2 back and forth. You may actually consider changing to the LGT parts if you're looking for a few extra inches of drop.
1 - 8 of 8 Posts
